FrankTruth
- Joined
- Oct 6, 2020
- Messages
- 17
Which is better? COB, CREE XP-L V6 or XHP70.2 LEDs
What are the best LEDs available today in order?
I'm new to really paying attention to flashlights myself, so I pulled up some PDFs, to see if I could figure it out.
First, let's get some tedious pedantry out of the way. A COB (chip on board), is different from the other two. Where the XP-L and the XHP are single LED emitters, the COB is a group of emitters, stuck together on one board. You can have a COB that's made with XP-Ls, or XHPs, but you really can't compare the three of them on an equal basis.
I'm going to link to the two PDFs that I found. Both are from CREE, I may be in a "gray area", forum-rules-wise, but they're for information purposes.
https://www.cree.com/led-components/media/documents/ds-XPL.pdf
https://www.cree.com/led-components/media/documents/ds-XHP702.pdf
If you read them, you may find your eyes glazing over, like mine did!
Near as I can tell, the XHPs are brighter, as in, they put out more Lumens. You have a lot (a lot!) of choices of how "white" or how "yellow" those Lumens look.
If I know anything from other gear-related forums, there is no such thing as an objective "best". If you're looking at the LED as the start of buying or building a light, I would argue that there are many other more important factors than the alphabet soup on the emitter. These include, but may not be limited to:
Cost
Size
Weight
Body material
IPX rating (dust and water "proofness")
Carry method (pocket clip, belt holster, sling)
Battery life
Battery type
"Throw" or "flood", or a little bit of both?
And, if you're secretly an engineer, and you're just trying to get a feel for what CPF considers the "best", then I'm just gonna go chew on my foot, for a little bit longer.
Which is better? n.a. V8 engine, Turbo diesel or an inline 4 with a Turbo?Which is better? COB, CREE XP-L V6 or XHP70.2 LEDs
I was looking for the latest, brightest, most energy efficient Cree LEDs.
I already took into consideration all the other criteria you listed, but I don't know how to compare the LEDs which are basically the heart and engine of every flashlight.
