Which LF bulb is like the P60?
Siskik
Mayo, FL
Does anyone know if any of the Lumens Factory bulbs compare to the P60's beam?
(The P60's hot spot is NOT that tightly focused and there is good spill. That's what I like about the P60.)
LumensFactory lamps don't do flood as well as SureFire lamps. The P60 equivalent (HO-6, or something like that) will have a tigter hotspot with greater throw.
What he said. Why not just get another P60?
I probably will get another P60. But, I was trying to use rechargeables with it. And as you know, the P60 will blow with rechargeables.
I know I can use them with a P90, but I like the floody beam of the P60.
The P90 is floody too, it is just like the P60 but more powerful.
If you want to use rechargeable pick up a 3.7V lamp like the HO-4, EO-4, or G&P 3.7V, or Wolf-Eyes 3.7V D26. then just run a 17670 in there.... I *think* you might like the G&P best because you can defocus them a little and still get a pleasantly smooth beam that is wider.
