Isthereanybodyoutthere
- Joined
- Jan 30, 2008
- Messages
- 170
When ordering from DX ,,Which one is better ,ultrafire or trustfire rcr123 ??
Which is better? IMHO....Neither.
Often times, people pose a question like this, and assume based upon the collective answers what action is best to take. When it comes to Lithium batteries, you must do your research beyond asking the question. Take note of the experience of the posters, and use the google search above to see how much has been previously discussed.
I hope you're not going to be disappointed. The AW cells might have a good trackrecord from a safety and consistancy point of view, but they have about the smallest capacity of the cells I've tested (I have not tested any ultrafires yet, btw). Their performance also drops quickly under higher loads.
Smallest capacity by what margin?
Have a look at Raymond's post:
http://candlepowerforums.com/vb/showthread.php?t=195712
Depends a bit on what you're comparing: time, mAh, or mWh.
But on average, 10-15% at the higher current rates. If you have a well regulated light, it could mean almost several minutes of extra runtime (36 minutes, instead of 30 for example)
I'm not saying that I think the AW's are bad cells. I think that the information that AW provides on the protection on his cells, makes them easier to trust than a lot of other cells. I've also found very little posts (almost none) that talk about problems with the AW cells, which is a good thing, even though I don't know how much cells are in circulation of the different brands.
Also, their size often make them a better choice than other cells (they have the same dimensions as a primary cell, most other protected cells are larger).
But strictly from a performance point of view, they're not the best.
It's up to you if you want to pay the premium for the AW's. They have a lot better chance of working when you receive them, their safety measures are well documented and they are said to be very consistent between cells.
