Which one is brighter??? Ultrafire C2 3w cree or DX U2 style 3w cree
Randy555
I hope someone could give some info. as to which light is actually brigther and would give longer runtime.
Cheers,
Randy:)
Well you probably won't get both brighter AND longer runtime with the same LED. But I can say the U2 style Cree which is pulling 1.4+ amps off my battery and probably putting at least 1.2 amps to the LED is very very bright. I think the Cree pulls just over 0.5 amps so it is not going to be as bright but will likely give longer runtimes.
Thanks for the reply matrixshaman, I had the regulated U2 for more than a week and it was very bright, and I am considering the Ultrafire C2 since its also a cree I was thinking its as bright but like you said its a bit less but with longer runtime. Do you think its comparable or greater than the previous 7watt lights from Dx.
Cheers,
Randy
I'm not too familiar with the 7 watt (Goldstein?) but I think that was a Lux V or Lux III being driven hard. I'd look at the claimed Lux readings on DX as I think Kyle does a good job of keeping things honest or compared to other lights there is consistency in his readings. I'd tend to think the U2 style Cree is about the brightest one there at the moment although some of the Seoul P4's might be close but I think all of them are direct drive (something I don't like in most lights).
Based on lightreviews.info
Ultrafire C2 = 6180lux
DX U2 Style= 5190lux
Not sure but why does my C2 seems so green?
I have both and the u2style is alot brighter (celling bounce test)than all 3 of my c2's.But the c2 lasts a long time on a set of batterys.
My DX "U2" is quickly becoming my favorite light for the money. It's definitely bright. I took the following picture last night on the side of my house. It's a pretty dark alley.
I just tried my c2 with 2 3.6v batteries Its alot brighter now pretty close if not equal to the u2 style.
The C2 I have found is very well regulated on two cells -- it draws more current from 3V primary cells than from fresh 3.8V LiIon cells. However, its brightness drops off significantly on one cell (only draws ~560mA from tailcap) -- but that should be good for long runtime, if that's desired. Throw is quite good. Build quality is also good -- and it has things like gold plated springs, solid feeling switch aluminum reflector. Several things I did not expect from a $20 light.
Mine has a slight greenish tint as well. I consider it a major advantage -- try taking any "true white" looking LED outdoors and compare it to your greenish Cree LED and you'll see what my mean -- in real world use, I find the greenish LEDs tend to render color much better.
