EFMax
Imagine two lights, one has a 12* spot and puts out about 2000L, the other has a 28* flood but puts out 3000L.. Both lights use the same bulb but different reflectors and lamp housing.
Assuming off road use and a need for good side vision as well as distance coverage, how would one workout (based on your own previous experiences) which light would give the appearance of best lighting ratio.. (also assume that you can't try before you buy).. cheers..
I know its a compromise but in my head I can't quite see if the side vision from the flood is offset by its ability to penetrate as deeply as the spot or does its extra output take its distance ability close to or beyond the spot. Manufactuers have no beamshot comparisons and the difference in price is not OTT.. TIA.
