I have a LED working at 4.5V 0.64A. the max LED temperature was 84.7C in infra red camera picture.
I applied some black ink(white board pen, mabe there is alcohol included) on LED package to avoid glare and make camera more efficient, but an amazing thing happened.
After turned on LED, looks there was chemical reaction happening bewteen pen ink and LED sealed resin, fortunately LED was still working.
Then, I took the camera, LED temperature was over 130C, but input power was still same 4.5V 0.6A.
In order to confirm this, I set TC on LED substrate near LED sealed resin bulb, it was 112C.
In the 2nd original sample TC temperature was 84.6C at same location.
There is a big heatsink under LED board, most of heat will tranfer to heasink and dissipate to ambient.In the 2nd original sample TC temperature was 84.6C at same location.
What's the problem? Who can tell the cause?
(sorry the IR picture can not work, I will try.)Hi DM51, Thanks for your opinion, my english is not good.
LED on board(a heatsink is under board) and IR pictures link:
http://13051785.photo.hexun.com/1677626_section.html
