most manufacturers still seem to have anal-rectal inversions
:lolsign:
Elektrolumens Minimak 14500 with Nite-ize headband - SSC-P4, Fraen optic, 14500, cutdown minim@g.
The torch in the OP should also fit the Nite-ize headband. The Fenix L2T/D and P2/3D are fatter but will go into the loop with some pushing. It is preferable to use a 2 cell light as the hot parts are further away from the loop and your head.
I've never had any of my homemade headlamps melting their own solder contacts, but I have had a melting plastic smell from a Luxeon K2.Heat is the primary concern [if you ever tried to wear a solder gun on your ear you'd understand the nervousness], and heat has a direct relationship with output.
And the radiant light energy would be absorbed (particularly with dark coloured cans) which would heat up the beer.Like I've said before you don't need 200 lumens to grab a beer out of the icechest at night while camping.
Good thing...I have built some battery packs that can actually drive the PT Apex on high for an extended time and they shut down due to heat. After about 15 min they work again....
Hi Nofair - were you in windy conditions that helped carry away the heat
from the PT Apex heat sink?
When doing runtime tests at home I have used a small fan to cool the light
thinking it would be a more realistic test for hiking and avoid any LED life shortening the heat might cause..
-hopkins
...I'm still laughing at the image of a cpu cooling fan attached to a headlamp!
Suppose you're already pumping 1.0amp into the LED why worry about
another 100mA for a cooling fan to prevent a thermal event? :thumbsup::thumbsup::thumbsup:
battery life matters too...
you don't want a light which you change batteries every hour...
That might be a tad front-heavy. :mecry:... a C/D cell pack. I think I would prefer to contain all in one unit instead of having addition wires.
It's nice to have the option. I installed a "turbo" button in my favourite headlamp yesterday, for a momentary brighter light.I mosty need runtime not 200 lumens. Thinking the same is true for others.
