NoNotAgain
Anodizing done in batch processing is extremely cheap to perform.
The military process Mil-A- 8625 type III is typically a natural color finish which varies from tan to olive green. Black anodizing is a dye added to the sealing operation.
Type III anodizing is a minimum of .002" thick and is done for abrasion resistance first, then corrosion resistance secondly. .002" doesn't sound like a lot of thickness, but that's per surface, so threads aren't the best thing for type III.
As for Ceracote, i'd do KG Coatings Gunkote instead. Can be performed at home and if you select the 1000 series material, it's room temperature cured.
Lauer Firearms offers a coating called Duracote. Duracote is Sherwin Williams Polane repackaged at five times the cost.
