Why does my P3D Q5 flicker on Low mode only?
Face
Hi,
I have a P3D Q5 (well, actually, it's a P3D Rebel 100 body with a replacement Q5 head - in case that makes any difference) and I noticed last night that it has a subtle flicker on Low mode only. I can't see it happening on any of the other modes (other than Strobe :) ) This isn't the low battery warning flicker - I've seen that enough times to know what that is.
I've De-oxit'd the tailcap spring and the positive battery point but the flicker is still there, although it may be even more subtle now - or it could well be placebo :)
Anyone have any ideas on what might be causing this and how to rectify it?
Thanks,
Face
Afaik this fenix light does not use PWM. It's possible you're seeing a regulation issue at the lowest level. The TK40 has a similiar issue (but hard to notice) on low if you follow a set sequence to cause it which is:
- Light ON (in any mode other than low)
- Cycle modes to get to low
- Light OFF
- Light ON
