The LSD improvements are 'just a bit' more than just a change in the separator.
The following is what Sanyo indicates they changed for the Eneloop batteries....
How was the self-discharge reduced?
Modern Ni-MH batteries consist of two metal stripes ( anode and cathode ),
which are separated by a non-conductive porous plastic foil ( separator ).
These three stripes are laid on top of each other and are winded to a coil.
This coil is put in a metal can and immersed with a liquid ( electrolyte ).
Then the metal can is closed with a cap.
The self discharge of Ni-MH batteries is caused by three main reasons:
- the chemical decomposition of the cathode,
- the natural disaggregation of the anode,
- Impurities of the anode.
Now, how could the self-discharge in the eneloop been reduced?
The chemical decomposition of the kathode has been reduced substantially by the use of a new superlattice alloy.
As an additional benefit the superlattice alloy increases the electrical capacity of the battery and reduces the internal resistance, which allows higher discharge currents.
Another advantage of the reduced decomposition of this alloy is the fact, that less Cobalt is needed to stabilize the alloy.
The anode has been strengthened by another new material, which reduces the natural disaggregation.
Additionally the separator and the used electrolyte have been optimised for low self discharge of the eneloop.
Here is the web site;
http://www.eneloop.info/home_en.html
Click on ... 'What's Eneloop' and then and then 'Technology'.
