blasterman
- Joined
- Jul 17, 2008
- Messages
- 1,802
To mods: Another forum member here had a tag at the end of his response I found to be sort of an attack. It also shows the general ignorance and myopia of many people on the issue of lighting technology. My purpose of responding is not to defend myself not directed at anybody in general (not sure where the original statement came from), but hopefully will be educational and discussion worthy.
A tag at the end of LEDNinja read :
First, who are these 'powers' ? The only powers I know of are VPs of marketing divisions of big box stores who in reality are really nothing more than Western Distributors for Asian factories trying to appease shareholders. There are already a jillion different types of MR-16 and standard base LED retrofits, and the concensus is that the cheapest ones found at Walmart are the best ones using the cheapest drivers that nobody knows if they meet code. Seriously, go look at the junk drivers on DealExtreme and tell me if you want this inside your ceiling cans. Guess what, most LED retrofits use this quality level of electronics. CFLs are actually worse because of the voltage ramp-ups required.
You quit your day job, and go to work at Walmart or target and design cheap consumer electronics for them with questionable U.L listings. The LED rods were throwing together here won't catch fire like a CFL will. The only reason LED retrofits exist is not because of some visionary at G.E. or Phillips wants to save the world, but because they know Western Consumers are basically stupid and will buy them.
Also, the science of fitting LEDs inside a standard base bulb basically comes down to eliminating heat with that package, and we've had that discussion resolved many times. There is nothing fancy here - LED retrofits are limited by how they can eliminate heat because of the format limitation, not how much light they can produce. That is universal knowledge.
However, every time a new LED bulb appears on the shelf at Walmart or K-mart with less lumens than a christmas ornament somebody here reviews it. Who cares? The bulb isn't going to get brighter because of the physical limitations above, and yet we get multiple responses from mensa candidates whining about how "LEDs aren't there" yet because that crappy bulb isn't as bright as their 75-watt Sylvania.
That's like SUV owners complaining about the high price of gas and telling me to design a more fuel efficient engine as a response to me telling you not to buy a large vehicle.
I find it ironic that 30 years a typical high-school kid would have little problem wiring a simple DC circuit with LEDs, but now it's suddenly quantum mechanics. Says a lot about Western Education systems and why a 7th grade in India or Korea now has a four head start on your 12th grade honor student. Sounds to me like somebody just can't figure out how to wire 3-LEDs in series and what resistor to use.
Local furniture stores sell high end lamps that cost over $400, and they plug into a damn wall socket, and couples buy those things by the half dozen for their new condo. They then stick $1.00 light bulbs in them because CFLs look like garbage and can't dim. Track lighting that uses line voltage can also be installed without the assistance of an electrician, so I don't know what your problem is. Either format presents me with limitless possibilities of desiging LED lighting with lumen values as high as I want them.
Shoving LEDs inside 100year old light bulb formats is the problem, and a format I want nothing to do with because it's dead and beaten to death by big Box stores selling cat litter next to table saws.
Yep, and they'll be cheap, built in Western China factories and almost certainly have the same problems as current CFLs.
Personally I could really care less what people buy, but perhaps the biggest slam against conventional bulb formats you seem to like so much is the fact corporate and industrial America stopped using them right after WWII. Seriously, go into an office building or warehouse or grocery store or factory anywhere on this planet and show me all the Thomas Edison era light bulbs, or GU / MR format bulbs being used. They almost entirely use Fl tubes, or HID, or increasingly solid state. Incan? Only if you run an art gallery. Now connect whatever brain cells are required to resolve that logic dilema.
There's a serious disjoint between true energy efficient technology adopated by corporate civilization and the whims of American consumers driven by laziness, horridly outdated home designs, and the Chinese backing your McMansion mortgage that looks just like 10 others on the street. The solution has nothing to do with what you buy in the aisle at Home Depot either even though marketing jerks are falling over themselves convincing you otherwise.
blasterman, stop whining about legacy fixtures. design a new energy star LED fixture that meets code and submit it to the powers that are considering alternatives to the good old Edison bulb.
You could become the 'Bill Gates' of the new green lighting industry.
You can not expect 300 million Americans and 30 million Canadians to design and build their own LED setup.
They are going to go to a lighting store, buy something they like the looks of and hire an electrician to install and wire it.
The CFL industry is coming out with GU 24 fixtures and bulbs.
We need someone to do something similar for LED.
