WHY PEAKBEAM DOESN`T OFFER LION PACKS ON ITS WEBSITE ANYMORE?
karlosk98
Hi everyone,
I plan to purchase a maxabeam with a lion battery, but I recently read somewhere that they are useful only in the high power mode.
Is it true? I Just recently checked peakbeam`s site an casually I couldn`t even find it`s new product as I did before.
Thanks
Hi everyone,
Thanks
They have them (MBP-1207L) in their product catalog pdf. Not sure why they don't setup html pages for their various products, since this pdf is 28mb download every time someone wants to look at it!!! :eek: The new ones you would purchase with Li-Ion work normally. The high power issue is with older generation models.
If you buy a Maxabeam together with the Li-Ion pack, it will work just like any other Maxabeam, normal, high and low output.
I believe the Li-Ion pack is a 14.8 volt 4 cell configuration. This will have a higher voltage than the NiCad or NiMh pack.
I talked with Peakbeam a while back, and was told that if you want to use the Li-Ion pack on a Maxabeam that came with the 12 volt battery, you would need to send the light in and have it recalibrated for the Li-Ion battery.
If memory serves, I while back a CPF member tried a 14.8 volt pack on his 12 volt Maxabeam, and it would only work on high output.
I hope this makes sense.
Thanks.
Do you know if both batteries produce 7.5 million CP?
