Would like info on this pack I'm trying to build 4S3P LIPO for G&P's 35 Watt HID
kabkbak7321
Allentown PA USA
I'm atemping to build this pack and would like to know if the pack balencer will be able to charge packs that are 4S3P.Or whould i need to have 3 balencers for this to be safe. Any help would be greatly welcomed.
Re: Would like info on this pack I'm trying to build 4S3P LIPO for G&P's 35 Watt HID
I see what you are trying to do, and although I am not an expert it looks OK to me.
The job of the balancer is to prevent the voltage on any cell exceeding the maximum of 4.15 V or so during charging.
If you put three 18650 cells in parallel, they will behave like a single 6600 mAh cell.
So as long as you build your pack as 3P-4S and balance each of the 3P's you should be fine. As I read your circuit diagram this is what you are planning to do.
You also seem to be within the maximum current rating of the components, which will be 6-7 A at the start of charge.
Therefore on paper at least, in my non-expert opinion it looks correct.
Hi,
I see that Mr. Happy answered already, so I will just agree with him.
The balancer is rated for up to 40 amps, and you are well within this.
I cannot quite tell if the packs are internally wired parallel, or if it goes through the balancer "become parallel, but it should be ok.
I assume you are using 18650 LiIon cells in this pack instead of LiPos to make it fit in the light. The current draw from the pack will be around 3 - 4 amps, so well under 1 C - nice long run time. :)
Since the balance appears to have low voltage protection, seems like a safe idea.
I like this setup. Now, if you coud fit some sub Cs in there, that would be amazing, but I am assuming this would not fit.
My son and I are starting to play with r/c cars, where this kind of pack is more common. So far, we are staying with NiMHs (Lixx is too risky for a 10 year old), but I am learning a whole new level of appreciation for chargers and battery pack power.
You might consider equipping the pack with astro zero loss connectors. Here is a very reasonably priced source.
http://www.rcmodels.ca/astro-zero-loss-connectors-p-265.html
Thank you both for the information here. I will start bulding the packs ASAP.
I just need to order the balencer. As for connectors I have been using DEENS connectors for a long time and this light had them from the factory,
I was very suprised to see them in there.The next time I need to order conectors I will give them a try.
As for LIPO"S that is from to many rc projects I just call them all the same thing but you are corect they are in deed 18650 LiIon cells.
I had to shave the HID balist side's to make it fit and even then the packs need to be built to the curvature of the light 2 packs of 5
one infront of the other and 2 cells ontop of the rear pack to clear the reflector.
I do beleave there is enough room left in the light to place 2 or 3 cree Q5's in the housing(not installed just laying in there to make noise).:laughing:
