65535
If you send me everything (long carrier, light charging jack needed (like on thecarrier) light) I should be able to make you somethign that owuld work well.
LuxLuthor said:I wish I had bought an extra battery holder with mine....I know how great this light is. I see you did not buy that light from that thread....did you try contacting the two or three who bought an extra battery holder? Nebula and Karlev I think were the ones I saw. Good Luck!
I talked to 5Mega and he said that he had no plans to build more...so I am almost out of luck...unless there is an extra one that someone is willing to let go...Nebula said:I did buy one extra, but it was for another custom light that came without a battery holder. When completely built out, I plan to give the light to a very deserving family member. Otherwise I would be happy to let it go.
I suspect that FM is working on more as I write this. Good luck in the search. Kirk
Neb, I just have a MagD cutdown...I didtnt get to the groupbuy fast enough...so I have everything else to make this except the battery holder... I was only aware of 1 run of the 1D here https://www.candlepowerforums.com/threads/146499&page=1&pp=30Nebula said:Choppers - I looked at the longer version of the battery holder again, and believe that the end piece can be cut down to work for you. Which FM 1D light do you have - the one from the 1st or 2nd GB? If you aren't sure tell me the color. I have both and want to make certain of the length before I cut one of my holders for a test. Let me know and I will go to work on this. Kirk
