metalhead69
Sorry. Vinh. I'm here for your lights. Moving on
i like this light more then my fenix tk61vn !
Can't wait for more photos! Even though I have the light I still like checking out beamshots!
I had little doubt your light was on high; I was just teasing you in the hopes that you would turn the head just a little bit harder to discover how easy it is to change modes. I'm glad you are now enjoying all three modes!
So your high mode is somewhere in between medium and low?
On my light, full tight is high mode, slightly loosening it from there gets you medium, and it continues to stay on medium as you continue loosening for a while (for roughly 30 degrees) and then it goes into low.
The Sony VTC5 works best in this light. I ve tried a few other imr and protected Panasonic and most can't even light it up.
Quite a fussy light to fuel but running on VTC5 this is amazing compact single cell thrower. I got all 3 levels nicely spaced on my xpg2 version.
Alex..:wave: will U (maybe) tell us why U like the S200C2vn more than the TK61vn please? Does the TK61vn don't have double the throw over the S200C2vn?
Patt
s200c2vn hotspot is more intense than the tk75.. although with high drain batts you get even more lux.
i 'm going to order some high drain at 2600mah..
HALLO!! i am looking to find also High drain battsbut i cant find in greece can you help me????
Ah. That helps bring our numbers closer then. I had recorded 728 lumens after 30 seconds and 137Kcd. I was using high drain cells though. So looks like we will line up nicely now with your newest numbers you will be releasing soon. Irregardless I know we have the usual led and manufacture variances that can make a difference.Yes, the missing MM15vn's in the mail is very frustrating. But the S200C2vn was indeed shipped to me earlier by Vinh, and that review is almost done. Just finishing some of the last analyses, and waiting for a clear night to do beamshots.
Some good news to report - I've done more extensive testing on a variety of battery types, and get even better output/throw performance on high-drain 18650 cells. Full details will be given in the upcoming review, but you can expect to see up to ~10% higher ANSI FL-1 numbers than what I originally reported (quoted below, which was based on my standard AW protected 2200mAh). Stay tuned ... the review should be up sometime this weekend. :wave:
Didn't look at this thread for several days and there is already heat!
Anyhow to get back on topic. I have been using both The S200C2vn in both XPG2 and XML2 and god....The more I play with them the more confused I am. At most times I am sure I like the XML2 version more and when I thought I madd up my mind I decided that the XPg2 version is truly a special light. How can something this small with a reflector throw 100K Lux!?
The SL Ultra Thrower might be the new single 18650 throw king when its released but the S200C2vn is still king in terms of size.
