As I understand it, all xenon bulbs (or most) are also technically halogen lamps. A "halogen bulb" seems to be kind of a loose term in the industry, as it pertains to any bulb that happens to have halogen in the fill gas mixture.
So, as I understand it, most bulbs labeled "xenon" or "krypton" contain xenon and krypton as a component in their delicate balance of inert heavy fill gases, halogen included.
disclaimer: this could all be wrong.
[edit in]
also... The reason xenon is *good* for bulbs, is that it is the densest fill gas commonly available. The more pressure and density of the fill gas, the less likely tungsten is to "evaporate" in the first place. So by combining ideal quantities of halogen and xenon (and whatever else, nitrogen maybe? at high pressures, they are getting a combination effect, the high pressure and high density of the fill gas "holds" the tungsten in place better, but with a halogen cycle in effect to attempt to re-deposit tungsten that does evaporate.
