If the outside of the light gets hot, you are fine. If only warm after about 3 to 5 minutes, than the LED life may
only be about 300 to 500 hours. Big deal. 20 to 30 hours with a standard Mag bulb. Still very cost
effective plus a lot more light.
The idea is to get the heat from the LED to the outside surface of the flashlight so that the heat can be
radiated to the air. A large heat sink inside the light does no good if that heat is retained inside the light.
Why?
I used NIMHs to set the right current. Problem was: they are pretty old and after 3 days laying around they lost a lot of charge (didnt expect so much)
I recharged them and tried the flashlight (i knew that i should be careful and measure current with fresh charged NIMHs again) and it was like: "oh wow, bright!" 1 sec later: "oh no! Blue!"
Measured: 2.2A or above (not like to kill it)...
But now its fine
and if dx would hurry up i wouldnt have to use a resistor in row...
