Just got this torch today after ordering over a week ago from china.
Chucked the batteries in the torch without charging, both full power and energy saver worked fine.
Chucked the batteries into the Ultrafire WF-137 charger which came with it.
Charged the battery till the green light stayed solid, then tried them in the torch.
Full power mode flashes for a spilt second before going out :(, energy saver mode works fine.
Checked the voltage on the battery to see if the charger had messed up, but it was 4.15ish volts. The ebay listing says the battery is a 3.7v 18650 protected battery, so I guess the charger is over charging it?
Is the led faulty or the charger or something else?
Thanks
SwissTony
Thanks
SwissTony
