I tested "super bright" white LEDs from various ebay sellers. LOV and JELEDHK's LEDs were the 55,000mcd rated versions and the CECE ones were rated 20,000 mcd. Given the throw (intensity) is about the same, I conclude that the rating of the 55cd ones are way overstated :laughing:
LEDs were tested at only 12.5 ma for 11 days. After 150 hours, the downward trend started. The good news is that after 270 hours they are still well above 70% original light output. I estimate the light output to fall below %70 after 500 hours and perhaps as soon as 400 hours if the curve steepens. I expect the latter to be true.
So there you have it. After less than 3 weeks the LEDs would have faded significantly at only 12.5ma :shakehead
Notes: Y axis is relative light output (not lumens)
Inconsistent test times were due to my availability to test them.
LEDs are known to increase in brightness slightly after a few hours of operation which might explain the slight bump I see in my tests.
