If you plan on running the light on high you are better off with a higher drain cell than the GA. Less voltage sag means the battery will not be working as hard to provide current meaning it will physically degrade less and run cooler.
I doubt it drops that low unless used in a warm environment or somewhere with little to no air circulation. Keep in mind the quoted runtimes for the PID modes are HIGHLY variable and dependent upon numerous factors. My best guess is that if it operates similar to the MK3 HI that the step-down will be to the 700-1000 lumen range after a few minutes depending on air circulation, temperature, etc. and possibly lower if used in warmer conditions or with no air circulation. Mileage will vary on this one and until we have it in our hands all we can do is guess.
The 429 lumen high mode is PID controlled - I guess that means it cannot sustain this level under normal conditions?
I'm looking for a 3200+ mAh hybrid IMR. Safe chemistry, laughs at heat, and can handle 15 Amps.
Err those don't exist just yet. You can either get the 3500mah GA or MJ1 which won't handle 15 amps or you can get the 3000mah 30Q HG2 which will. As of this point in time there is the capacity/amp tradeoff.
If you want to run the light on high you are better off with the 30Q/HG2 and if you want to run it on low you are better off with the MJ1/GA. That tradeoff does still exist, both INR and NCR are "safe" chemistries at least compared to ICR.
Thanks for your help. Much appreciated. Looks like 30Q or HG2 are in my future for this light and maybe my Astrolux S41 (it draws almost 10 Amps). Curious, do you have a preference between the 30Q and HG2?
Accidentally activated in my pocket? If it prevents ouchies and LED degradation in that scenario, I am all for it. PID regulation doesn't have to mean that it has to step down under normal use, but can mean that the light can step down under specific circumstances.What is normal? Gripped in someones hand? Sitting on a table? Ambient 20deg C or 25deg C? I think there is no normal, but a very wide range.
Thanks, will definitely add some 30Q's to my next battery purchase. Then I can compare the GA's, MJ1's and the 30Q's.Pictures snipped.
I agree I don't know if you were replying to my post by mistake or you mis interpreted what I wrote. I have no problem with all levels being PID, does not mean anything; the more the merrier. It specifically does not mean what the manufacturer thinks is 'normal', it's only one indicator of the range of conditions under which they are considering the operation of the device.Accidentally activated in my pocket? If it prevents ouchies and LED degradation in that scenario, I am all for it. PID regulation doesn't have to mean that it has to step down under normal use, but can mean that the light can step down under specific circumstances.
I know. I was just trying the add an example for the person you were replying to (Connor).I agree I don't know if you were replying to my post by mistake or you mis interpreted what I wrote. I have no problem with all levels being PID, does not mean anything; the more the merrier. It specifically does not mean what the manufacturer thinks is 'normal', it's only one indicator of the range of conditions under which they are considering the operation of the device.
Not going to happen with the NCR18650GA. Mind that the ZL is not able to sustain the 1500 lumens for very long (except in a freezer/Antarctica). It will drop brightness and current consumption pretty quickly and settle at ~400 lumens after a few minutes.
I think he did OK except for the yellow, it should be more towards the less save region it seems based on reported events. I agree with the current distinction between the IMR and standard chemistry not because of how they respond under regular use, but how easy they are to trigger into thermal run away. Testing has showed that IMR is much better at handling physical damage.You didn't get the more/less safe part quite right. All proper cells regardless of chemistry will have a predetermined breaking point and should not explode because the canister breaks open before enough pressure for a "real" explosion can build up.
Some chemistries are more prone to doing that than others, but it's not like these vent and those explode - they all "vent with flame" once a certain temperature/pressure is reached.
Except when the predetermined breaking point fails .. then they go
