i can no where find a 1.5 m impact resistance sign on Zebralight's website most other high quality lights offer.
hi Zebrix, welcome. (nice nick!!)
impact resistance is one of my fav topic on cpf, i've got some experience with it and had posted already my 2 cents in various threads. here a short recap of observations and opinions re this important topic:
[[1]] 1.0-2.0m are enough to make ANY loaded light fail (e.g. broken glass lens) when dropped 100% vertically bezel down. it is the most critical impact angle. unless the bezel is protected with rubber or heat shrinkable wrap (Rayovac Indestructible), at least the glass lens will break. and the probability of failure depends heavily on the hardness and flatness of the ground too. concrete, asphalt, coal tar, garden tiles are plastically soft (or uneven) and often forgiving whereas mirror-like flat grounds made of ceramic tiles or marble tiles ..etc..; in a typical U.S. household the ground is made out of wood or you let the light drop EITHER on an uneven surface (garden tiles) OR at impact angles other than 90° vertical, so the glass lens or the interior electronics should not break. Btw, at 90° vertical angle, a battery cell could also damage the driver disc through the impact. In other words, much is/can be damaged when a light drops perfectly vertical on a perfectly flat, even, superhard surface! I did a couple of drop tests with brand-name flashlights (and i should have recorded them on video) and all lights eventually failed when dropped 100% vertically on ceramic tiles.
[[2]] Of the Top10-Most-Reputable-flashlight brands
the more clever ones DO NOT give any impact resistance ANSI FL1 STANDARD rating:
- ZEBRALIGHT
- HDS
- 4SEVENS (FOURSEVENS)
- EAGLETAC (EAGTAC)
And there are other companies which publish (at first sight) impressive drop test videos but dont give any ANSI FL1 STANDARD rating either:
- Xeno Co.
- Prometheus Alpha
According to Fenix, the revised ANSI FL1 STANDARD demands that only full numbers are to be specified in the rating, i.e. it is forbidden to specify "1.2m", "1.5m" or "1.8m" and the manufacturer has to decide whether to publish "1m" or "2m" as impact resistance. However, not all companies adhere to (or are aware of) the revised standard, or dont care.
Clearly, if i was a flashlight manufacturer i wouldnt specify the impact resistance either .. because proudly stating things like "1.5m impact resistance" will make some dumba$$ customers feel invited to perform a tentative series of drop tests in front of friends or a video camera for boasting purposes. 4sevens company philosophy is "to understate and to overdeliver". In the case of impact resistance, it is correct and wiser to shut the h*ll up
regarding this topic and state NOTHING. no claims, nothing. Zebralight users, HDS users, 4Sevens users, Eagletac users, Xeno users, Prometheus Alpha users are then INDIRECTLY WARNED that their lights should not by any means be dropped at all. As a consequence, the users will take better care of the lights and will not mistakenly think that they (or their lights) are safe.
Imho, the concept of impact resistance is, because of [[1]], silly and futile. Jetbeam is a funny company: they publish specs and also drop test videos (on garden tiles) with harmless impact angles. at some point the Jetbeams (glass lens) fail, as documented in the videos.
[[3]] If you know the majority of popular China-made power LED flashlights and compare their difference in construction and rated ANSI FL1 STANDARD impact resistance, then you will come to the conclusion that the lights are internally built very similar and that the manufacturers have little means to improve impact resistance. Most rate theirs at 1m or 1.5m (forbidden!). Seldom will you see 1.8m (forbidden!) or 2m ratings. internally designers use 2 o-rings to cushion the glass lens (or they use plastic lenses see Surefire, Maglite, Rayovac), and HDS has a potted driver in addition. That's about it. In practice 1m or 2m rating isnt worth pos if the light is dropped according to [[1]].
[[4]] My advice is: Ignore all and any impact resistance ratings. Treat each light equally well. Dont think mistakenly that you're safe only because you have read user reports or watched Xeno, Jetbeam or Prometheus Alpha -company-made-videos (none of which use static 90° impact angles!). Never drop your light on superhard surfaces like bathroom tiles or stairway marble tiles. If you know that your light will get dropped often, then protect the head with heat shrinkable wrap or a rubber band (or the whole torch wrapped in paracord
), or attach it with a long lanyard (or wrist strap) to your belt. And if the torch malfunctions after a drop (on a softer surface, say concrete or tar), then make use of your 10 years performance guarantee by the manufacturer (Zebralight, 4Sevens, Eagletac, Maglite, Surefire, Rayovac, etc.). Some torches have a long track record and are considered quite rugged on cpf, see the many positive comments regarding Fenix E01, Fenix LD20, Fenix LD01, 4Sevens Quarks, and HDS: many users had dropped their sample
multiple times and the light survived.
i am wondering how often Zebralight owners drop their lights (or McGizmo owners) lol.
