As an EDC I like the UI of my Olight S1 better
I don't know if I like it better than ZebraLight's UI, but I certainly like the Olight S1 interface just as much.
Olight was wise to take Moonlight mode off the main sequence. The S1 interface gives you shortcuts from off for Moonlight and High modes. Once on, you can also press-and-hold to cycle through Low, Medium, and High modes.
Here is a link the table I made describing the interface of the Olight S1 Baton.
The ZebraLight user interface is actually quite straightforward. I must confess, however, I have seem some pretty confusing explanations of it.
Here is my streamlined description, taken from a previous post.
From off:
1 click = hi
2 clicks = med
3 clicks = strobe/beacon
4 clicks = battery check
Press & hold (momentarily) = low
Press & hold (longer) = cycle: low, med, hi, repeat
Once on:
1 click = off
2 clicks = switch to an alternate for the mode you are in (low, med, hi, strobe)
Press & hold = cycle: low, med, hi, repeat
The alternate modes you select when the flashlight is on will be memorized. If you select an alternate low mode, for instance, the next time you go to low, your alternate will be used. Ditto for med, hi, and strobe.
Programming the alternate modes:
In any of the constant brightness modes (low, med, hi), double-click 6 times (i.e., click 12 times fast). After that, double-click some more to cycle through the available alternates. When you see one that you like, click once to select it. This will also turn off the flashlight.
Hope this helps.
The press and hold momentarily for low is what doesn't work well for me.
This is one place where ZebraLight could take a cue from Olight. Most ZL owners would probably like the UI better if press-and-hold from off—no matter how long—took you to Low mode. That's how the S1 works.
After the ZebraLight is on, press-and-hold should cycle through the modes of the main sequence: Low, Medium, and High. From off, however, only Low mode should be reachable with a press-and-hold. Again, that is exactly how the S1 behaves.
I have the SC32w, and love it. I use it everyday. I have not had to contact customer service, so I can't tell you about that. At first I thought the light was a bit small, but I got used to it. Now I prefer it. It easily fits into my pocket. I wouldn't mind having another one just like it!Looking for a edc. Really looking for a cr123 simply because I can get them free at work and they are common. The 18650s are not common. Looking at the sc32 zebralight
I like the fact it is so feature packed but the UI seems clunky. How is it in everyday use? Also how is this brands reliability/customer service
Is it just me or is holding and starting a ZL in low the easiest thing ever? Maybe I just have amazing timing/reaction skills and should have been a drag car racer?
SC600 mkiii would be my EDC if I were feeling ok about carrying a $100 light every day... favorite UI for sure. As it is i carry either a R16vn if I will be out in the dark, or one of a couple of smaller things for a normal work day (indoor, closer-up needs).
