HKJ
[size=+3]Vapcell INR18650 3000mAh K30 (Gold) 2020[/size]
Official specifications:
A fairly high capacity 18650 battery that can deliver a decent amount of current.
The two batteries matches nicely, the battery is fairly constant it capacity with different loads, but it gets warm at high currents and I damaged one of the batteries at 30A.
[size=+3]Conclusion[/size]
This cell has a decent performance for the capacity and current.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
- Model: K30 INR18650 3000mah 15A
- Size: 18.3*64.9mm
- Nominal voltage: 3.60V
- End-of-charge voltage: 4.20V
- End-of-discharge Voltage: 2.5V
- Typical Capacity: 3000mAh (0.2C discharge)
- Min capacity: 2900mAh (0.2C discharge)
- Weight: Max:48g
- Internal resistance: Max:15mOhm AC 1kHz
- Standard Charge: 1500mA,CCCV 100mA cut-off
- Quick Charge Current: 4000mA
- Max Continuous Discharge Current: 15A
- Max Discharge Current: 30A
