chanamasala said:
Flashlightreviews.com has this going to 50% brightness at 1hr on the regular batteries at setting 1. With a 2400mAh 18650, around how much longer will it run on setting 1 to 50%? If Xmas dough comes in, a U2 with 18650s sounds like quite the setup.
According to this thread, new U2s are coming with a glued plastic insert that prevents an 18650 from fitting. Some folks have managed to remove it easily while others have had trouble getting it out.
http://candlepowerforums.com/vb/showthread.php?t=99132
I was about to order a U2 until I saw this and decided to wait. It's too expensive a flashlight to have a warranty claim denied because I removed the insert and the 18650 use was very important to me.
Emillion is running a sale that's about to end on a multiple level Lux V called the QuickSilver V in the dealer forum for $60 shipped. I just ordered one. I've got the Lux 3 version from Wai On, a 3.5W Lux III called the VB-16 and like it a lot. The QS V is about as close as I'm going to get to a U2 unless the 18650 "issue" gets "resolved".
From what I remember, run time of a U2 on an 18650 was about 1.5 hours with about 10% less output than when run on 2 x CR123A.
Mike
