Rob M
Hello everyone!
I have just been given a load of small lithium batteries, they are all approximately 1/2 AA size, and give 3v, though some are a tiny bit bigger than 1/2 AA, same length but slightly bigger circumference (won't fit in a AA MAG tube) and supply 3.7v.
I am hoping to buy a lathe soon, one project will be to make cylindrical bodies that will fit these batteries and different LEDs.
My question is, what driver and LED would you recommend? I'd like to have a small, regulated light, with a smooth spot. It's mainly for use in my house, at night, checking on my kids after they have gone to sleep for instance, so low and high brightness levels would be a definite advantage. I want this light to be as small as possible and run off a single 3v or 3.7v battery if possible.
I have bought and dismantled an Inova 4-mode microlight, and despite the low voltage (these lights are designed to run on 6v, from two flat lithium 3v button batteries) the chip and LED work well. From the 3.7v batteries, the brightness is almost the same, while it is a little dimmer, but still adequate from the 3v batteries.
I was wondering what your suggestions would be (apart from the Inova!) for a regulated driver that would make the batteries last as long as possible while providing low and high modes, with a beam adequate for indoor use while being smooth enough for reading a book? A physically small driver that would fit in an AA size tube would be ideal, perhaps one of those 10mm LEDs that were mentioned on here by Milkyspit would be nice?
Any ideas or suggestions would be gratefully received!
