There is enough of a demand for tri and quad Lux lights that there are ready made heatsinks that allow for one to be built. I'm in no way volunteering, but they usually go for $130 and up. Actually, if you don't mind the size, they are actually pretty effecient. I built one using 3 RW0H Lux I stars and IMS20 reflectors that runs direct on 3 D cells and it is impressive. R-bins put out between 40 and 50 lumens at spec and using a Vf of H, 3 alkalines will very slightly overdrive them so I figure an average of 45 lumens per star. Three of these make 135 lumens and draws about 1.12amps. That means that you will get very good battery lifetime... just a bit less than a single Lux III.
Icarus made a few pretty trick little lights with three T or U bins but runtime probably isn't going to be amazing on high though with a 2 stage switch, the low probably puts out a very usable amount of light. They also cost a couple bucks...
The particular light I built puts out a HUGE hotspot. Of course, it's kinda triangular up close, but in actual use outdoors, you don't really notice. It's just like about six times the size of a single Lux III in a Mag reflector.
You could do something similar in a cutdown 1C sized mag that ran in a single 18650 with less runtime of course. I'd imagine it would be close to an hour plus or minus.
