CLB
I recently bought a new Surefire A2, and was initially impressed, like so many others, by the incandescent light. Although the beam was not as perfectly round as my E2E, I believed the voltage regulation feature would more than compensate. However, with the initial set of batteries, the lamp initially dropped out of regulation in what seemed a surprisingly short time, and then intermittently went in and out of regulation for awhile. So I put in a fresh set of Surefire batteries, and timed the runtime of the incandescent lamp. After 39 minutes, the lamp dimmed (presumably dropping out of regulation) for about 45 seconds, then brightened again to full intensity. Over the next eight minutes, the lamp alternated intermittently between the dim and bright levels, and then finally stayed dim. The lamp continued to gradually dim further, until the filament went completely cold about 15 minutes later. The net result is that the incandescent lamp is reliable for less than 40 minutes on a set of batteries, which is disappointing.
Now, this does not sound like the behavior described by other A2 owners on CPF. And the runtime chart in QuickBeam's review indicates a longer time in regulation, and does not indicate a period of intermittent dimming and brightening as the light falls out of regulation. But, before I call Surefire, I am very interested in hearing if the behavior of my A2 is typical of other units out there. I will certainly be grateful for any input you care to offer.
I have learned so much already from CPF that it is probably audacious of me to make my first post an imposition for help. I hope I can be on the contributing side in the future. Thanks.
--Chuck
--Chuck
