kingkong said:hi,
I got the Head out using the Freeze method, but how do you get the LED out? They are glue? heat method?
Thank,
cuong.
kingkong said:hi,
Thank,
cuong.
nemul said:pop the little white piece of plastic off the middle. under there unscrew the little screw, i think it torx or hex.. now if it's HAIII or older model the LED' and board are siliconed in. if you cant resolder to the board you can try my way!
http://candlepowerforums.com/vb/showthread.php?p=1125517
