Any problem using Battery Station rechargeable 123's in SF L2?
Aviator
San Diego, CA
I just found Battery Station, and I'm considering buying their rechargeable 123's, but i'm a little concerned about the voltage. Their 123's are rated at 3.6V and can be as high as 4.2V right off the charger. Would 8V be too much for my L2's Luxeon to handle(as opposed to 6V)?
Aviator
San Diego, CA
AW said:
Thanks! I dont understand though....it says the 14670 is a 3.7V battery, and that you only need 1 to power the L2. That doesn't make any sense, because the L2 is designed to run on 2 3V 123's in series, right? Which means it's designed for 6V. So how can it possibly run on almost half the voltage, and put out anywhere near the same amount of lumens??
jar3ds
USA
i got my L2 to fire up with an MP unprotected li-ion and a 123 battery spacer from lighthound :D
FlashKat
Anaheim, CA.
Hi Aviator,
I have been using RCR123 batteries from batteryspace.com that are rated at 3.0 volts, and have not had a problem with them in my Streamlight 2L 3W luxeon light or my 7 w Golston. Originally I tried their 3.6 volt rechargeables in my Streamlight 1L Twin Task and blew out the Xenon bulb, and switched to the 3.0 volt RCR123 batteries with "NO PROBLEMS". Make sure you get the 3.0 volt RCR123 batteries.
Specs. 3.6 volt RCR123 batteries measure 4.10 volts charged
3.0 volt RCR123 batteries measure 3.94 volts charged
