wquiles
In this post I created a POP-based, hand-built module for a 9-5mm LED head, which I used in a 6P from a 168S LiIon cell. Due to being POP-based, this LED light is my most used light within my house, usually at a low level. However, sometimes I go to full-bost level, and sometimes my daughter gets a hold of it and without knowing she gets the light to full-power as well (my POP is setup for LOW then HIGH).
I liked the module so much that I added an external grounded spring to allow it to work on my favorite host, the G2. Yes, the module is not pretty, but it works awesome:
As shown in the post linked above, the light draws about 61mA to each poor LED, which I though was "OK" for occasional use. Boy was I wrong - this is how it looks after 6 months of use (this is on LOW):
First one LED, then the second, then the third .... The "dying" LED first starts to flicker on "HIGH", but works OK on low, until eventually it does not light even on LOW
I suspect that the LED's die "open circuit" so the remaining LED's get even more current (they are all wired in parallel), so it is only going to get worst with time.
Although expensive, since this is my MOST used LED light, I am going to replace the LED's with the uncut MJLED's, which can take about 100mA, which is significantly higher than the 60mA or so that the circuit can provide. Hopefully the LED's will then last a looooooonnnngggggg time
Will
Will
