GhostReaction
The only reason I hated so much about this little light was the twisty switch which is very unreliable and inconsistent.
Till I ve read at Lighthound site that the newer Aunoc aaaa have a metal bit instead of the original spring to improve the twisty switch.
So i decided to stick a piece of folded aluminium foil in the spring to see if that will help solve the crappy switching.
Foil folded and stuck in between the spring.
Now for the beam shot.
ARC aaa on left with new E2 batt and Aunoc aaaa with a used E2 aaaa batt
Aunoc from off with half a turn till "low"?
Further twisting the head till about 1 complete turn, "high"?
rther
Next I replaced the Aunoc with a fresh E2 aaaa batt.
ARC vs Aunoc on "low":
ARC vs Aunoc on "high":
I m still puzzled about this. Maybe the aluminium foil in between the spring had provided some resistant when lightly contacted the battery. So that mean on high, fully turned, the aluminium foil is directly pressed in between the batt and the board contacts.
Even with the "2 stage" effect the switch still felt unreliable and inconsistent, and I still wont EDC it :nana:
As edited, I ve traded with the newer switch and this light deserve a place back at the keychain
rther
