BrighTor
Hi All,
I just finished my first "built" light...a 2D ROP. It was indeed a snap.l It seems to be running pretty darned bright on 6 energizer 2500's with a MOP camless reflector from the Sandwich Shoppe.
I do have a question though...in Modamag's cammed/camless group buy thread, he shows a modification to teh bulb/switch assembly for use with a camless reflector. I don't really like the "floody" light with the very obvious artifacts and wire shadow things that are showing up. On a hunch I put the stock reflector back in and dialed it down to spot and bam! Much nicer throw and the artifacts were not really noticeable.
My question is this: Is the mod shown in Modamag's thread one that's commonly done? Can I just do it with an electric drill and a steady hand? It surely looks simple enough. Is there a certain measured distance I should make the top of the "loop back" of the hole so that it'll be at the same spot
the stock reflector would put it?
Thanks very much for any suggestions. I did try to search the forums (I promise!), but I didn't find anything in the first couple of runs, and the forums have seemed VERY slow for the last day or so, so I gave up.
Thanks again,
Rob
Thanks again,
Rob
