ledaholic
Around Christmas I bought a hand held spotlight at Fry's for about $5.00. I didn't expect much and I was right. It had a 6 v SLA battery and a halogen bulb and a glass window. The battery almost lasted a month before it went belly up. I bought a modified M@g 10 w HID and an extra bulb the other day and was thinking I still had those 10 w ballasts from a set of spotlights I took off my motorcycle. They used a different bulb but had the same base as the WA 10w bulb. So I decided to upgrade the $5.00 light.
After the mod.
I removed the H3 fitting from the reflector and checked for bulb clerance and depth requirements. As it turned out I needed to ream the reflector for a 1in hole. Then I needed to shim the ballast up about 1/8 inch to get a good focus. I epoxied a washer of the proper thickness to the base of the reflector and then used high temp RTV to attach the ballast to the washer.
I had some 4500mah NIMH batts doing nothing so I put together an 11 cell pack cause the ballast is 12.something to 13. something volts.
Everything fit perfectly and I now have a nice cheap HID!
And a beamshot from about 4 feet.
Looks like will have a fairly descent beam. Cant wait till tonight to really check it out.
After the mod.
