<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Zephyr:
And I was about to return my Minimag tomorrow too, for I thought I would have no use for it since I have my Lambda Illuminator. But I guess I'll decide to keep it now. Count me in for one please!
Lambda,
Do you have to drill a bigger hole on the reflector to make the pill fit? Or that wouldn't be necessary since all of the parts will be included in the kit already? By the way, Lamda, you are a genious!!!!!
Thank you very much, and happy Memorial Day to everyone!!
ZEPH <HR></BLOCKQUOTE>
No drilling required; the reflector gets tossed and replaced with the Luxeon collomator lens.
The kit would consist of:
Illuminator pill - same "guts" (DC/DC converter & Luxeon) that go into the Illuminator, less the Illuminator heatsink. The pill uses heavy copper clad to move the heat to the battery tube lip. So, it will be the same brightness as the Illuminator, but slightly warmer. Tests show max temp to be 50C, which is 10C less than a Luxeon with optics and heatsink stabilizes at when drawing 350ma.
Luxeon Lens - to replace the reflector.
Lens gasket - this holds the lens firmly in the head assembly.
Even if you've never done a mod before, this should only take you 5 or 10 min to finish.
Price; probably about ~$29.95US
