Handlobraesing
Banned
- Joined
- Feb 14, 2006
- Messages
- 2,724
I bought a Dorcy 3D metallic grey flashlight from Target for $11 a while back. The stock emitter is a Luxeon I Star driven through a 1.2 ohm series resistor. My first mod was replace the emitter with a Luxeon III, bypass the resistor and assemble using thermal compound.
Unlike, Maglite, the thermal path in this light is excellent. The Luxeon Star never becomes too hot to use and after about 30 minutes of use, the entire aluminum body of the flashlight becomes warm, which indicates excellent heat conduction.
When you have the head installed, it is an excellent thrower with very clean beam. With the head removed, it's an asesome flood light.
I would like to rip apart a Mag 3D LED module and integrate the circuit into the area below the LED mounting plate in this light and use it to drive the heatsinked Luxeon Star. In the absense of LED heating up, the Mag driver should throttle considerably less than inside a Maglite in the crummy fat PR base.
Any thoughts?
Any thoughts?
