It's tricky comparing small flashlights to Maglites. Even xenon Surefires compared to Maglites. This is because of the reflector. A Surefire E2E might advertize "four times the light of a big two D-cell flashlight", and this is probably an accurate statement, but because of the larger reflector on the Mag, plus its ability to focus tighter, the Mag will far outthrow the Surefire ("throw" is the term we use for how far a flashlight can project its beam). You'd need a Turbohead Surefire (M3T, M4, M6) to compete with a Maglite in throw (these will annihilate a Mag).
If you compare your new 3W or 5W Nuwai to a 3D Maglite and excpet it to outshine the Mag in every situation, you'll be dissappointed. The only way an LED can match the throw of a Mag is if you stick an LED inside the Mag. Overall output might be more though, so closer up it'll be more useful. And of course, the biggest advantage of these smaller 3W and 5W lights is that they're small.
