KDOG3
Ok, I've got the soldering iron and the solder, I've got the 2 part Arctic Silver thermal adhesive, got the new TXOH emitter.
First things first. How do I remove the old emitter off the heatsink? How do I remove the white heatsink goo from around the emitter and the heatsink? Its' a 1-to-1 mix with the 2 part adhesive, correct? How long do you let it sit befor testing out/reassembling for use? Anything that I'm missing?
