mossyoak,
I am currently doing an evaluation of the L1 (old) vs. the L1 (new) since I couldn't find enough info about this anywhere else. So far, I have only done runtime tests on "low" with the following results:
The L1 (old) ran in "low" continuously (with occasional 1-2 second bursts to "hi" just to see if it still worked) for 208 hours. It fell to "moon-mode" (very dim) at about 160 hours, but the "hi" mode continued to work (albeit contankerously) until the 197-hour point. The L1 (old) worked normally in all respects to the 153-hour point, moon mode at 160 hours, "hi" mode until 197 hours, 208 hours to "death".
The L1 (new) ran in "low" continuously (with occasional 1-2 second burts to "hi" just to see if it still worked) for 168-176 hours. It fell to "moon-mode" (very dim) at about 118 hours, but the "hi" mode continued to work until the 118 hour point. (Apparently, this "last gasp" effort to "hi" at 118 hours CAUSED the fall to "moon-mode"). The L1 (new) worked normally in all respects to the 90 hour point, moon mode at 118 hours, "hi" mode until 118 hours, 168-176 hours to "death". (I was asleep when it died in the night sometime!) [It began to ease down to moon mode at 90 hours but was very subtle. It became more obvious at 102 hours, and was fully engaged in moon mode at 118 hours.]
These preliminary numbers are impressive, and my tests continue. This is merely a first report to your post. I have a lot of testing to do. The main reason that I was interested in the L1 (new) as an EDC was the potential runtime on one battery with the newly added "distance capability", but I had no idea that it would run THIS long. I feel that it is basically a useless light without the F04 beamshaper on the front of it for short-range flood, but if I am going to EDC a light, it must also have SOME distance potential. This one does.
Hope some of this helps.
Flashdark sends.
