Was trying a different lens for my HDS EDC and while trying to fit the lens, it has become stuck. Not enough edge to get anything sufficient to pry it out unfortunately.
There is the obvious by drilling it out but I'd like to be able to remove the lens so that I can try fitting it again after reducing the diamater .1mm.
Some possibilities:
Can the HDS light engine be removed from the backside
I could try to drill a spanner type hole on each side of the lens and use the thin spanner tips to unscrew it. I suspect that taking a drill bit that close to the edge will likely result in damaging the adjacent treads though.
Other thoughts?
Some possibilities:
Other thoughts?
