decided to start a separate thread for others to discuss and post problems/lack of problems with the Streamlight Survivor LED. Not that there are that many, since I think the problem below is the only issue so far.
Good and bad news. I got my light today, but a vertical shake towards the head causes it to go off. I have a 17.56 MB video here of how it acts when shaken vertically. The lady at BrightGuy asked if I had heard if there were any problems with the light going out when shaken since they had this happen with one of their customer's lights. I mentioned I had not- until I received mine.:ironic:
I'm not really that worried about it, since I believe I can fix it. I think I know exactly what the problem is. The batteries in the carrier are a loose fit on the ends, i.e. they slide along their length about 2mm or so.
When the light is shaken vertically the weight of the batteries is compressing the contact springs inside the light which opens the circuit. Since the light is microprocessor controlled, any complete loss of voltage causes the light to go off and remain off until turned back on.
I can't believe they didn't put springs in the carrier- seems like a no brainer to me.
I will solder my own springs in the carrier or something similar to remedy the problem. Or maybe add a foam washers inside the other end of the carrier to keep the batteries tight against the contacts pictured below. On second thought, foam washers won't work because of the 2 halves of the carrier. Maybe instead of springs, I will solder a loop of 12 ga. copper wire to each contact.
I sure hope Streamlight takes care of this problem, I can't imagine being a firefighter and having a light go out on you because you jolted it and constantly having to turn it back on. Of course, this may be a non issue for them since they will most likely be using the rechargeable packs.
Don't get me wrong here, I absolutely love this light!! This is just something that needs fixed and can be easily done so IMO.
