I dont own the Peli M6, but I do own the U2 and have had the Gladius before. Of the two I've had, I'd be hard pressed to choose between them (the Gladius was a loaner from my cousin). I'd choose based on which features you need, as, for the U2 & Gladius at any rate, the features of each light are quite different.
The U2
+ can easily take in 18650 li-on batteries***edit***sorry the OLD versions at least
+ is relatively simple to use, having a selector ring for 6 levels of light
+ brighter than the Gladius overall, using a LuxV
+ has a nice beam that's right on the line between flood and throw, if that is your thing. "ram of light" they call it... =P
= more floody than the Gladius
= suffer about 9-10% drop in brightness on highest level when going to 18650s
- less "throwy" than the Gladius in absolute numbers, but you might not notice this in practical use
- can be operated one-handed, but awkward to do so (you have to change positions to turn it on/off, and then to switch levels)
- dim is too damn bright
The Gladius
+ tight, focused hotspot that throws
+ very many brightness levels (small steps from dim to bright)
+ can go as dim as you need it to (if dim is your thing)
+ extremely disorientating strobe, made more effective by its focused hotspot
+ all functions can be accessed from one point (tailcap operation), no need to change positions
= sidespill a bit dimmer than U2, but still useable
- to step through all the levels from dim to bright, although not that slow, is cumbersome.
- overall not as bright as the U2, if you need overall brightness
- can't use li-ons very well (you get the 15-second "low battery" blink while you use em so i hear)
Here are some pics & beamshots. Click on any for a larger version.
[left pair: SF U2, Gladius, highest level] [right pair: SF U2, Gladius, lowest level]
Corridor reference:
SF U2, 2xcr123:
SF U2, 18650:
Gladius:
whole gallery is
here if you wanna see comparisons with some other lights.
