KDOG3
This is the first battery I've seen that the ends are completely flat. This is causing a problem with the KL1 head. Where the positive contact terminal is on the KL1, its even with the black plastic thing that its mounted on. The shoulders of the battery rest on that, not allowing the end of the battery to contact that little "nub". I rigged up a little spring up with some electrical tape seen below. Not pretty, I know. My question is can I put a gob of solder on the positive end of the battery? Will it stay put? Any safety issues? Charging seems to work ok though....
