NewBie
*Retired*
The massive US-based retail chain will install LED lights in 500 stores, saving $2.6 million annually in energy costs.
Wal-Mart Stores is to deploy LED lighting from GELcore in low- and medium-temperature refrigerated display cases in over 500 U.S. stores. The retailer expects that energy cost savings of a 500-store retrofit -- one of the top energy-saving initiatives that it will pursue in 2007 -- will exceed $2.6 million annually.
Of note:
"In stores where the new GE LED products will be put to work, Wal-Mart expects to net up to 66 percent energy savings, compared with incumbent fluorescent technology."
And
"The combined environmental impact of a 500-store installation represents an annual 35-million pound reduction of carbon dioxide emissions. It also equals the good that comes from planting over 4,464 acres of trees or removing over 3,143 cars from the road for every year the LED lighting operates in place of fluorescent lighting."
http://ledsmagazine.com/articles/news/3/11/16?alert=1
Related stuff:
-Folks prefer LED lighting:
"The lighting within the display case was much more uniform with the LED lighting system compared to the traditional fluorescent system. The results from the human subject experiment show that subjects strongly preferred the display case with the LED lighting. Considering the luminous efficacy of white LEDs presently available in the marketplace, it is possible to develop a LED based lighting system for commercial refrigerators that is competitive with fluorescent lighting system in terms of energy use. The LED based lighting would provide better lighting than traditional fluorescent lighting"
http://www.lrc.rpi.edu/programs/solidstate/completedProjects.asp?ID=52
See page 44 for the scores:
http://www.efficiencyvermont.com/pages/BBBD2006/docs/Leslie-Lighting Matters_ Results.pdf
From GelCore:
"Primary benefits of GE's RoHS-compliant, UL-approved LED Refrigerated Display Lighting solution include:
• Improved product visibility with reduced light-source glare on products and floors
• Hidden light source provides better access to products for stockers and consumers
• More robust and better for the environment than fluorescent lamps because it doesn't contain glass or mercury and it doesn't produce UV or infrared light
• Up to 78 percent energy savings compared with VHO fluorescent lamps in a 5-door fixture
• Over two times the life of fluorescent lamps in a cold environment reduces maintenance costs and hassles (50,000 vs. 18,000 hours)
GE's LED Refrigerated Display Lighting solution also saves watts by lessening the load on the compressor. For every light watt reduced in a frozen food case, the compressor works less hard, saving ~ 0.45 watts. On a 5-door case, the additional energy savings from a reduced load on the compressor, can reach 70 watts vs. T8 fluorescent; 134 watts vs. HO fluorescent; and 330 watts vs. VHO fluorescent."
http://www.gelcore.com/literature/GELcore_WalMart_refrig_announcement_DE_FINAL_111406.pdf
The product that is utilized:
http://www.gelcore.com/product.php?id=51
And on top of it all, the LEDs they are using don't have very high efficiencies!
1280 lumens/41 Watts = 31.22 lm/W
http://www.gelcore.com/literature/RefrigSpecSheetWEB7_7_06.pdf
Also to consider with fluorescent lamps, most don't realize the large losses in fluorescent fixtures, plus the additional losses in the ballast, that cause the usable lm/W to drop quite significantly, from what everyone runs around touting. Additionally, in this case, the cool environment also comes into play, which benefits LEDs. But with fluorescent lamps it requires extra power input into the fluorescent bulbs to keep them warm, which also loads down the refrigerator cooling system, for even more losses.
Of note:
And
Related stuff:
From GelCore:
