chesterqw said:
TIR optics CAN have 100% efficiency but not all TIR optics can do that.
however neither can reflectors have 100% efficiency most only have around 97%.
How is this possible? Are you talking very specialty glass with sophisticated A/R coating? Even so, i'd be surprised if you could get above 99%. Most polycarbonate (read: affordable) lenses are in the 85%-95% efficiency, of which *all* the light passes through. A reflector based solution will have maybe 30% of the light hitting the reflector, then passing through the glass, while the other 70% passes only through the glass. Those numbers depend on a lot of design aspects, though.
If you are a volume manufacturer, a custom TIR lens will cost you maybe $0.25 (after you pay for tooling), while a simple high transmissivity glass window with A/R for a reflector can cost you a couple dollars (not to mention the reflective coating you want). If you cheap out on reflector components, your efficiencies are in the low 80%.
From my research, when cost is a definite consideration, the TIR lens wins in efficiency. For a bit more money, a quality reflector design can be more efficient than a budget TIR design. With even more money... well, i haven't had that luxury.
At the end of the day, though, we are only talking about 5-10% efficiency differences, which pretty much nobody will be able to distinguish the brightness between. Cost, packaging, and other issues become much more important.
Can you explain more about your 100% efficiency claim?
