Look what I got in the mail today!!!!! The three lights on the right are the 10.00 1 watt AA. Not much to talk about. Very dim Light.
The one on the far left is the MINI-PALM - VERY BRIGHT,and alot smaller than your normal 1 WATT AA Light. Cant get to the head but the switch is totally different. Its a real clicky. Youve got momentary, then ON/OFF.
The second one from the left is the PALM BLAZE...and boy does it ever. The brightest 3 watt light Ive ever seen. Its uses the K2. This light is ALOT brighter than the MAXSTAR 5. Cant get to head of it either. This one also has a real clicky. Momentary then ON/OFF. Uses two cr123 batteries. Theyll be a link at the bottom of this page to tell you where to get these. Ill be doing run time test later. Ill post them when Im done.So far Im very impressed with the PALM BLAZE AND THE MINI PALM.
PALM BLAZE
Different kind of lens on both.
This is the beam from the Mini Palm in a dark basement at about 8 feet.
This is the beam from the PALM BLAZE in a dark basement at about 8 feet. Note the SQUARE BEAM from the K2.
THE PALM BLAZE switch.
The MINI PALM switch.
Side by side comparison of size with the Mini Palm and the Ultrafire WF602A1.
The MINIPALM is 24.99 and the PALM BLAZE is 39.99.
You can find all these lights here.
http://www.goldengadgets.com/index.php?cName=led-flashlights-highpower-leds
PALM BLAZE
