TranquillityBase
- Joined
- Jun 12, 2005
- Messages
- 3,741
You will see two photos that show a spacer washer...This is sandwiched between the LE and the reflector...It allows proper focusing of the led, and is a dead-stop for the LE...You can crank the LE as tight as you prefer, and the focus will not be affected. For E-series compatability, and by design of the reflector and LE, this spacer is necessary.
The spacer also bridges the gap between the LE and the reflector, creating a thermo path to the reflector...The chamfer side of the washer mates to the base of the reflector, and the flat side of the washer bears against the can, of the LE. This spacer washer could be permanently attached to the reflector base, or the LE can, with some thermo epoxy...Not bad idea for a Titanium head.
I hope you like it...
TB
TB
