chimo
I finally started playing with the Trit vials I purchased from B@rt.
I wanted to add some Trit to my Cree'd MiniFLuPIC. I decided to go the external route. I used some scrap optical plastic (likely pulled from an old VCR). It drilled pretty easily and was very clear, so I figured it would do the trick.
I used a mini-torch to reflow the plastic to take off the sanding/trimming haze, but I applied a little too much heat in a spot or two and formed some bubbles. I used some clear silicone adhesive to plug the bottom.
The vial functions well. Here are a few shots.
Trit size (for scale purposes)
With MiniFLuPIC Cree on a 10280 body. (Varied exposures - attenuated flash with long exposure.)
