I don't know if this has been brought up before, but I was wondering if this will work: A Surefire MN21 500lm bulb in a M3T. Both are rated at 9v so it should technically work. What I'm concern with is the load the battery will be under for such a power drain. I have tried the MN20 in the M3T before and it worked just fine for show, but never left on for long periods of time.
I don't intend to use the MN21 in the M3T for extended periods of time, just to amuse my friends. I know the run time would be close to 10 minutes or less if it works, and that is fine.
Any thoughts are greatly appreciated.
Thanks,
Thanks,
