22hornet
During the last days I did some runtime testing with the following lights:
- Surefire E1L
- Fenix P1
Batteries used:
- WAMA RCR123 600mAh 3.0volt
- Surefire E1L: Little less than 30 minutes before it starts dimming.
Dimming goes very gradually and takes a few minutes to become obvious.
- Fenix P1 (standard, 1 output model): 45 minutes before the light switches out.
Taking into account that the output of the P1 is about 40% higher than the E1L (Flashlightreviews: 28 vs 20) and also the far better regulation of the P1, I have new respect for the small but mighty Fenix .
28 to 30 minutes of full power might be OK for a Surefire L2 on high mode but for a E1L, it is quite disappointing :shakehead.
Should you wonder: yes, I switched batteries between the two lights so as to eliminate the influence of that factor.
Kind regards,
Joris
- Surefire E1L
- Fenix P1
Batteries used:
Kind regards,
Joris
