Thanks for the replies on this one guys:goodjob:
As suspected by most, I'm gonna blame this one on the batteries, or one in particular to be exact. I went through all the cells individually and in one group of 4, three read 1.1, and the last read .83. I threw all four in the charger and the weak link read .36 after charging. So I guess something happened inside the battery that must have freaked everything out. Even at 14+ volts I should have had no problem, so that battery must have been reversing, or cutting voltage, or something funky.
I didn't get an exact duplication of conditions tonight. At a balmy 4 degrees with -16 windchill (the windchill is more important in regards to me, the rider
), I took the long way home tonight and went over the hills and through the woods. After a little over an hour out there, no problems. The batteries do get to a point where at 1mA level 5 and 8 are indiscernable from each other and the light draws down a little, but it still is kickin'.
The words of everyone in regards to Li-Ion are well heeded, and in fact I already have a Li-Ion battery pack on order, but it got back ordered on me. Instead of waiting around and only running one or two LED's I just broke out some AA's and made a temporary battery pack. Which is also a pretty good plan to have a setup like this if you want a relatively cheap backup battery "just in case".
